- Joined
- Mar 3, 2010
- Messages
- 2,451
The problem is the hose fittings are leaking a tad, about a few ounces every 1000 miles. I have been adding Prestone Honda/Acura fluid and the cold pour has to be atrocious. It has been VERY cold in MN these last few weeks. -30 windchill has been rough on it, when I added fluid it was like pudding at those temps from my trunk, the pump is so stiff it nearly doesn't allow my car to start from the fluid thickness and intermittently works until 10 mins of running time and smells like burnt rubber probably from belt slipping on start.
I believe this is the original 270k mile pump as well. Before I cut the belt and roll like every other Honda I've owned I figured I would consult the forums to see what PSF I can use in the pump to limp it along in the cold but not kill it, PS is nice and id rather not lose it if I have a choice.
I'd sooner cut the belt then pay 6 dollars per 12 oz at the Honda dealer.
