Autozone's Valucraft oil. It's still SF rated! There's even a warning on the back not to use it in vehicles manufactured after 1988.
Info: http://www.machinerylubrication.com/article_detail.asp?articleid=518&relatedbookgroup=Maintenancequote:
Originally posted by Thomas Pyrek:
thanks for the heads up on the starburst thing. I'll be sure to not buy PC oil either.
Most any oil could be called SF rated since an SL oil would almost certainly pass SF requirements.quote:
THANK YOU for the great link to Machinery Lubrication. Sure explains things.quote:
Given that, perhaps it's safe to answer this thread, "Oils that Suck?" with the response:
Energy Conserving/ API Starburst oils SUCK!
99 cents a quart.quote:
How much did they want for that Puma oil?
Heh. Something to put in a classic Dusenberg.
Motorbike:quote:
Originally posted by Motorbike:
I've kept careful track of fuel economy in my HD equipment, and back when I used Esso XD-3, I would run 15W-40 summer and 0W-30 "Arctic" winter.
Your speaking diesel engines I suppose ? If not , twist that around and use the 0w-30 in the summer when all gas motors and I presume diesel too run more efficient . You'll see a marked increase in fuel mileage and it adds up over the course of time . The Industry is trending eventually to soley 30wts for the diesel's and 20wts for the gassers and there is a reason for it...to help save our Earths recources and the environment .
Also , you can't compare the 15w-50 synthetic on the low end of a 50wt to a hi cSt 15w40 tractor oil . Well I guess you can , in everday start,stop-n-go the Mobil synlube will get better mileage , way more CF than the dino typical diesel oil .Enter a highly friction modified PCMO 30wt and lower formulated by experts that get paid the big bucks and one can reap the benefits of even better fuel mileage without excessive engine wear .
There are countless stories of plain old PCMO 30wt taking engines beyond 250k . All the while saving fuel over a heavy wt oil used out of application .
I've taken three 302's to over 200k miles each using 10w-30 and helped save some fuel and the environment for my children's children and their children . My committment to a responsible take on lubing my engines will remain just that , and bet I'll not loose an engine either.
Again , no flames , no problems just how I see it based on some fact .
No intent to punish anyone. Just don't want the greens in my crankcase. "Energy Conserving" oils are only here because of CAFE and CAFE is only here because of the green lobby.quote:
Originally posted by TC:
... now I hear something to the effect of "Punish the treehuggers by NOT buying Energy Conserving oils." Let your politics dictate what you look for on an oil label??? Reject certain weights and friction modifiers because they're "PC"? Okey dokey...
