"Stuff the longest rod that can fit in the engine." - Smokey Yunick
all I get is this, but in reply I can see it
Bingo. The time that the piston is stopped, is called the dwell period.
dwell (plural dwells) (engineering) A period of time in which a system or component remains in a given state. (engineering) A brief pause in the motion of part of a mechanism to allow an operation to be completed. [\quote]
Dwell means this, the whole world knows it, so how long is this dwell time for the being being stopped? I did not bold the words, the definition was bolded.
That's what I get when I clicked the attachment.That looks like BITOG website, not the one I linked to.
Dwell is a period of time, like 4sec, or 9min, or cooked in oven for 75min.dwell (plural dwells) (engineering) A period of time in which a system or component remains in a given state. (engineering) A brief pause in the motion of part of a mechanism to allow an operation to be completed.
Yeah ... dwell, when piston V=0 (ie, stopped) for a specific crankshaft angle.
Ok, where's the flat spot in the graph where piston motion is paused at v=0 for some some period of time (dwell)? There is no dwell where v=0.
What's the period of time where the piston has paused motion? Is this question too hard, or you just not wanting to answer it?
I did not miss it.Guess you missed my post where I said you need way more graph resolution than the graphs being posted.
Take the piston velocity equation in that link and run a program (Excel would work) with super fine crank angle step resolution (like 0.00001 degree) and a very slow crank RPM.
Yes, a time period is some time period, call it dwell or any other word if you like. What's the actual dwell time period the piston has paused it's motion? Math will tell us an exact #, but I can't seem to find what the # is, can you help find the actual time period? Is it "one millionth of a microsecond", or some other period?Dwell can be one millionth of a microsecond too (a period of time) ... it's still dwell.
And if the time period is that small does it make any diff whatsoever that the piston paused for that small time period? I would think the issue is only present when the pause is on same magnitude of, and bit longer than, the time it takes for the film layer to become useless (as explained by other people), so up front quick no-math analysis it seems the piston cannot stop for very very very small time period, otherwise the film layer would still be there and not be an issue.
This is like arguing how do you ever know you're at 5 on a number line and not 5.000000000000000000000000000000000000000000000000000000000000000000000001. These are continuous functions and concepts so when someone selects exactly 5, then it's just 5. When someone says velocity is zero, it's just zero, for how long is not really important.
You can stop at 5 and wait there for 10min to eat some lunch, or you can pass right on by 5 at speed of light and spend no time at all at 5. The 1st case is no motion for 10min, the 2nd is always motion.
Plus you nor the OP will ever travel at the speed of light, someone with a degree in nucklear egineering would know thatspeaking of speed of light, if you are sitting and watching TV ... at any given moment are you in past, present or the future? You are in the present but continuously transitioning ...
think of t0+t as t approaches 0 ...
if you select a bigger/longer t, you can argue during that delta t, you were in the past, present and the future at the same time.
In the other thread you said the math doesn't work or is not satisfied or support that the piston has stopped ... and I explained that it does.
