Hello again everyone
, I've been talking to some people but would like a wide discussion on what weight you guys would run next.
Like mentioned I have a 4.0 straight 6. I have tried many oil weight combos to try to solve this minor lifter ticking. Right now it has been optimal and almost completely non existent with my current setup of 5qt 10w30 PHM and 1qt of 5w30 PHM and a Motorcraft FL1A filter. Here in the summer the ticking does not last for more than 10 seconds at most. But when the cold comes it will get worse (obviously).
I have tried PYB 6qt 10w30, PYB 5qt 10w30 and 1 qt 5w30, PHM 6qt 10w40, PHM 6 qt 10w30 and PHM 5qt 10w30 and 1qt of 5w30. Upon them, it seems like my 4.0 likes the thicker PHM BUT likes the flow of the 5w better at cold start to battle the cold start tick.
And here is where I'd like your opinion or criticism on my thoughts. My next oil change should be in august and then the following oil change should be right around december or january (super cold months in PA). I was thinking of two options for the August oil change that will initially be warmer temps but as I head into fall the temps will be falling.
1.) PHM 4qts of 10w30 and 2qts of 5w30 since it will be transitioning to colder temps in the fall
2.) PHM 5qts of 5w30 and 1qt of 10w40.
I plan on doing number 2 definitely for the winter. After discussing with KayCeeJeep he has noted that the 5w30 tends to shear around 3000mi. Is #2 risking it with hot august but cooler fall? I'm a little more worried if I run it in the hot august months and oil pressure really drops...
As a side note: my oil pressure 'seems' fine per the gauge on the dash. 55-58psi at cold start, normal driving hot 40-45psi and hot at idle fluctuates between 28-32psi. No power loss at all - funny thing and even my father mentioned it, my 2002 4.0 actually has a quick throttle response and has more power than his 2004 4.0 WJ
I appreciate all responses
