Any suggestions as to what weight synthetic would be best suited to these bearing clearances in a stressed daily driven turbo engine? The bore is also set up pretty loose as this is a high boost, high compression (10.0:1) and nitrous application.
Main Bearing Clearances: Listed 1-5
.0015 - .0015 - .0013 - .0015 - .0014
Rod Bearing Clearances: Listed 1-4
.0012 - .00125 - .0013 - .0012
Bore Clearance: IE bore size minus piston size.
.004 every cylinder 1-4
I am asking because my first 3000 mile change (Amsoil 10-40) is coming up and will be sending off for my first UOA, but I would like to try something else for the next change and to also have it UOA'd. Thanks for any suggestions.
jeff
www.swordfishGSX.8m.com
jeff
