So I have this 4 banger 4afe Geo Prizm engine with 139K on it. It seems to miss at constant speed and idles rough. Did 2 AutoRX treatment, some neutra in the gas and crank, changes spark plug wires/rotor/cap, clean throttle body, checked distributor, and igntion coil, changed spark plugs, transmission fluid flush, coolant flush, rebuilt spark plugs, checked battery and cables, cleaned starting injector, cleaned AirMass Sensor.
What it does is in the morning or when the car is cold for hours at least 12hrs, it usually never starts on the first try..i can sit there and crank for 15sec...and nothing...but if I crank it once for like 1-2sec and crank the second time it's ok...even then it flutters.
That didnt bother me as much, and the problem was gradual till the last couple of months which is constant.
The slight miss in the constant speed was cured in the past with new ignition wires (MEGASPARK crappy wires from KRAGEN) but now it's back..it seems like whenever I get a new set after 6months, the missing dissapears or is less dominate. Now its back and I'm a bit tired of it, it also seems to flutter at idle during stop and go traffic.
THe car normally uses 5w30 or 10w30, could a thicker oil like 10w40 make things better? Assuming one of the piston has some small compression issue? Could it be the ignitor module..that;s the only thing I dont know how to test but to replace it.
Or should I stay away from cheap wires? I haven't heard of anyone having problems with megaspark wires...just that they are cheap and don't last long.
Mileage is great if not better than stock after the autorx treatment, went from 26mi/gal to about 29mi/gal.
Any suggestions?
Thanks
