I generally change engine oil myself. (If you want a job done right, do it yourself.)
I have an 11-year old Ford Focus with 127,000 miles on it. I’ve changed the oil 28 times so far, always with full synthetic.
The last time I tried to change the oil I couldn’t get the plug out, even with the longest wrench I had available. The most expedient solution was to take it to a quick-lube joint. I specifically picked one that offered Mobil-1.
I told them to use 4.5 quarts of Mobil-1 5W-20.
Two hours after I got home, I pulled the dipstick. The oil-pan was a bit over-filled. (I suspect they put in 5 quarts. Either that, or they didn’t let the pan fully drain.)
When I examined the paperwork, it said Mobil-1 0W-20, not 5W-20. I was furious. I called them and they said that they no longer carry 5W-20, and 0W-20 is an acceptable alternative. So I asked them why the owner’s manual doesn’t say that. They said it’s because 0W-20 didn’t exist when the car was built.
Even if they’re right, I don’t think they had any business deviating from my request without telling me.
What do you think? Will using 0W-20 potentially cause any problems?
(By the way, the last time I had an oil analysis at Blackstone Labs at around 100,000 miles, they said, “Whatever you’re doing, just keep doing it.”)
