If you had an engine that "might" be prone to oil starvation issues what can you do to help protect things as best as possible ?. There have been a few people with my engine that have recorded low oil pressure and then a subsequent connecting rod bearing knock. I'm thinking it's an oil starvation issue.
Should we keep viscosity on the thinner side and possibly using an oil with higher amounts of Moly ?, that's about all I could think of. This engine has a balance shaft system, not sure why but it seems that some engines with balance shaft systems seem to be more prone to oil starvation issues. I could be wrong but that's what I've seemed to notice. The engine is also factory turbocharged but I don't think that has anything to do with the issue.
Any suggestions on ways to keep things as safe as can be ?
thanks
thanks
