well it all depends where you measure the temps and during what driving conditions. Typical city driving conditions , sump temperatures would be well under 200 degrees, probably in the 120-160 range. At a track running WOT max revs lap after lap, temps can get into the high 200's.
I've got an 02 Civic SiR - base k20 engine, I can get a rough estimate of oil temps using a heat gun shining on the oil filter and oil pan. I've taken some readings before but I cant remember the exact numbers, if I get a chance I'll try to take some more readings once again.
