Oil TEMPERATURE advice requested...
1,500 miles...that might take a year with this car! LOL
Back on topic. Are there any 'rules of thumb' or grades that have a tendency to run cooler in my type of engine?
I like the suggestion someone mentioned of running of running a HDEO like Rotella. You don't need flat tappets or a diesel to run HDEO's -- the modern Group II formulated HDEO's are so good some use them in gas engines because they perform so well.
Quote:
etrucker …
According to Matt Ansari, heavy-duty automotive manager at ChevronTexaco Global Lubricants, “With the advent of Group II base oils made with Chevron Isosyn technology, these impurities, which used to consist of at least 10 percent of the base oil, have been reduced to less than 1 percent. Once the oxidation problem was resolved, it became almost impossible to distinguish between synthetic oils and mineral oils in terms of fighting the hostile environment in an engine.”
Cherillo agrees. “If you refine mineral oils enough, they resemble synthetics,” …
Chevron research compares the performance of Chevron Delo 400 15w40, made from Group II base stock, with a 5W-40 synthetic oil; oil changes were made at 45,000 miles. It shows the mineral oil performs as well as or better than the synthetic oil in fuel economy, oil condition (including viscosity) and engine wear.
… it’s clear the most highly refined mineral oils now have a much greater resistance to extreme temperatures than in the past.
Since your temperatures really aren’t "that" high, I also would consider dropping down to at least a 40 weight -- 15w40. Chevron Delo 400, Rotella T, …… several choices, and they should cost considerably less than synthetics.
