Hi, y'all. Great board you have here. I've been reading it a good bit, searching, and learning more about oil than most people ever care to know. But there are a lot of factors for deciding on an oil for this particular application, and I feel like I could greatly benefit from some real expert advice on this.
What I've got is a '91 all-wheel-drive Olds Bravada. I've put a rebuilt early block 4 bolt 350 V8 in it, with a moderately high-lift, flat-tappet hydraulic cam. Standard stock replacement oil pump. It's carbureted of course, so no O2 sensors to be concerned about, and there are no catalytic converters. A very old-school setup.
Here's where it gets unusual... Some alterations had to be made in order to fit that engine into this truck. To clear the front axle and differential, it required a notched oil pan. It's a deep-sump pan, a bit wider than stock. Due to the front driveshaft being in the way, I also had to install a remote oil filter kit. Because the headers are run the way they are I also installed a large oil cooler. There's not much room and my radiator needs all the air it can get, so I had to put the oil cooler under the hood with a 9" electric fan on it, so I'm sure that cooler isn't performing as well as it could.
When I first put this together it was during summer in Mississippi. I quickly discovered I had cooling issues, so I installed a Corvette radiator, but I don't have room for a large fan, so in sustained heavy traffic the coolant occasionally still gets hotter than I'd like it to. About 225. But on the highway and in milder weather (like now) it runs at a steady 190.
My concern is oil pressure, heat, and lifter noise. These problems don't come into play until the engine is hot, but as long as I don't get on the highway there are no problems. I finally discovered after replacing too many starters, that my headers were to blame. They were burning my starter (which is now heavily shielded) and they're heating my oil at sustained cruising speeds. Exhaust is too close to the oil pan and I'm pretty sure there's nothing I can do about that.
I'll start the engine up and the pressure will be a nice and healthy 40-60 PSI. At operating temperature I'll idle at about 500 RPMs with just under 10 PSI, and run with literally just over 10 lbs for every 1000 RPMs. This acceptable from what I've read, and to be expected since my oil has to travel through six feet of 1/2" hose, a remote filter and an oil cooler, and I'm using the pressure tap on top of the engine behind the distributor. At this point there is no lifter noise. But after I've run it on the highway for a while and the oil heats up from the headers, my idle pressure is just barely above the peg and I can hear my lifters clicking. Cruising pressure at 2000 RPMs is about 20 lbs.
I'm not going to ignore the idea that it could be bearing tolerances, but I think my problem is heat. I started off with Advance Auto's store brand 10w30, and the heat made that stuff useless even faster than with their 20w50 that I'm running now.
I'm told that synthetics can handle high temperatures a lot better than conventional oils. I started to buy a bunch of Castrol Syntec, but then I read that it's not technically a synthetic and is petroleum-based. Some people have told me that a thicker oil will raise my oil pressure, while others say that I need a thinner oil because of my remote filter, hoses and cooler.
I'm looking for a reccomendation on a good oil that I can find locally, which will stand up to extreme heat, keep the pressure up, and tolerate the occational weekend drag race or autocross. Winter is a non-issue here. About 30 F is as bad as it gets. I was considering Castrol Syntec or Mobil 1 Truck/SUV.
Another consideration is, I've got an 8-quart pan and probably at least 2 quarts in the filter, hoses and cooler. I'm reluctant to spend $6 a quart with that kind of capacity, but if that's what it takes I'll do it...
Sorry this message got so long, and thanks for your help!
Again, excellent site you have here.
