Originally Posted By: 2Slow
Even if the engine would prefer lower viscocity, I am a little leary about lowering the viscoscity much as it is the same lube for the trans sump. Many manual trans / axle configurations run a fairly high viscocity lube compared to 40w engine oil.
The seals are the same between my engine and the Cooper S, so I doubt there would be any issue going to the 70 PSI spring, but I doubt I should mess with a system that works.
-Joe
yep it's kind of a strange combo. Never understood using the same oil for your trans.
My alfa trans requires a 80w90!
Can't imagine how it would feel with a 40wt oil.
Those trans are also very HP points.
I have Motul HP Moly treated oil in my gear trans.
Maybe a Liqui Moly oil that's got plenty of anti-wear moly in it for the trans? You could possibly use a lighter oil then.
What's the factory recommendation?
Do you know that the factory OP recommendations are?
My alfa manual states what the min and max OP should be.
-Joe
