Oil Shelf Life
Dayton, OH
I recently came across a case of Schaeffer's 7000 Supreme 5w30 that I have had for just over 10 years. Does anything become unstable after a certain period of time? Any shelf life concerns at all or just use it?
Thanks
10 years is probably the limit for the shelf life of an oil, I wouldn't use it in anything other than a lawnmower now.
Why is it lawnmowers always get the short end of the stick?
Don't all engines deserve TLC, I use GC in mine.
I think if you used maybe a quart or two along with some new stuff for oil changes you'd be fine... just don't go with long OCIs.
Because you can typically beat the crap out of a lawnmower engine and it'll still work fine. I'd think it would take quite a while to get rid of a whole case in a mower, though. For oil that old, I'd probably just recycle it.
BTW, I have M1 in my mower.
Why do you think motor oil, with all of its anti-oxidation additives, would go "bad" in sealed bottles? This is not salad oil. ExxonMobil actually rates its aviation oils for 30 years shelf life in quart bottles.
quote:
Because I'm an airline pilot and not a chemist. That's why I asked a simple honest question directed towards people that know more about it than I do.
cargopilot, if the bottles are sealed and were stored in a cool dry area, I would use the oil with confidence knowing Scheaffers builds a very high quality oil.
Not required but if you have any LC consider adding LubeControl at 2 ounces per qt to provide a little extra oxidation resistance.
I would be happy to do a Virgin oil analysis for you on 4 ounces of the oil if you want that too.
Contact me for special airline pilot pricing !!!
[email protected]
Sorry cargopilot,
I was not intending to insult or offend. It was more a response to the "lawnmower" answers anyway. This topic comes up from time to time and I just recently ran accross the answer from XOM.
If it can last 5-10K miles in a car Iwould not worry about it. The rating have changed so you may not want it a newer vehicle that has a higher API rating required.
