I just changed the spark plugs on my recently purchased used 2000 Subaru Outback 2.5L gasoline 4-cyl, 100k miles. This is the first spark plug change I've done since purchasing the used vehicle.
Whilst changing the spark plugs, I noted some amount of engine oil around what I believe are the valve cover spark plug gaskets. Is this normal? It wasn't like gushing out, but the spark plug hole was sort of wet with oil. I have changed spark plugs on a few other vehicles and recall seeing perhaps a little oil in that area, but not this much.
This vehicle does not seem to consume/leak any oil; I don't see any drips on the garage floor or on the valve covers and I haven't had to add any make up oil.
One thing I'm wondering is I think this vehicle had a 'tune-up' not too long before I purchased it. The spark plug wires, belts and hoses all look pretty new. I'm wondering if they checked the valve clearances (removed valve covers) during this 'tune-up', since it's recommended to be done at 105k miles. Perhaps the valve cover spark plugs gaskets should've been replaced at that time? Thanks guys!
