quote:
Originally posted by kev99sl:
[QUOTE] So what you're insinuating is that the high PPM we see with soft metals in Red Line analyses stems from their use of Moly?
Naturally not, the question was about base oil. In my post concerning Red Line I expressed my supposition that one of the reasons of non-impressive UOAs with RL could be its base stock and namely esters, i.e. what is perfect for racing does not usually mean good for everyday use. Hear probably I have to duplicate my original post in order to avoid some misunderstanding:
"I am afraid that higher wear numbers for ester oils come from higher corrosive/oxidative wear. It is noticed that mineral and semi-synthetic oils usually exibit lower corrosivity then fully synthetic oils, especially for relatively short intervals 7.000-9.000 km. Then the difference in corrosive wear starts to decrease and to 15.000 km synthetic oils would have only slightly worse or equal numbers with mineral or semi-synthetic oils.
If to compare synthetic oils, according to tests run by our car magazine ester based oils showed considerably higher corrosivity then oils formulated mainly with PAO. To mesure weight loss of metal plates due to corrosion at 9.000 and 15.000 km it was used high temperature oxidation test (1 hour is considered as about 3.000 km). In the same table you will find shear stability. Unfortunately the procedure was not decribed: I could find only that they applied a higher temperature then 100 C (possible they used the same CEC L-14-A-93 with over 100 C and over 30 cycles).
...................................... Corrosion, g ........... Shear stability, %
Motul 300V 5W-30 ............. 7,0 ... 17,8 ............ - 9,0 ... - 3,0
Motul 8100 0W-40 ...................... 16,0 ....................... - 43,3
Shell Helix Ultra 0W-40 .................. 1,8 ....................... - 26,9
Mobil1 0W-40 ............................. 12,0 ...................... - 32,6
Castrol RS 0W-40 ......................... 7,0 ....................... - 49,5
Liqui Moly Synth. 5W-40 ................ 7,1 ....................... - 23,1
Chevron Delo-400 5W-40 ............. 10,0 ....................... - 40,0
Shell Helix Plus 10W-40 ....... 0,1 .... 8,2 .......... - 14,0 ... - 24,0
Castrol GTX5 10W-40 ......... 0,7 .... 3,3 .......... - 11,0 ... - 28,0
BP Visco 3000 10W-40 ........ 0,3 .... 6,0 ........... + 7,2 .... - 4,0
Valvoline Dura Blend ........... 3,7 ... 10,5 .......... - 25,0 ... - 27,0
Esso Ultra 10W-40 ............. 3,2 ... 11,0 .......... - 24,0 ... - 13,0
Castrol GTD 10W-40 ........... 2,0 .... 9,0 .......... - 10,0 ... - 29,0
Shell Helix Super 10W-40 .... 3,2 ... 12,0 .......... - 18,0 ... - 13,0
Liqui Moly Tour. 10W-40 ..... 5,6 ... 19,0 .......... + 12,0 ... + 41,0 "
