Oil Recommendations for Toyota 2SZ-FE Engine
Europe
I have a French built Toyota Yaris with the 2SZ-FE 1.3 VVTI Engine.I have a choice between these three oils
Valvoline Synpower FE 5w30 Mannol 7709 OEM 5w30 Mobil 1 3000 X1 FE 5w30
Which one would you recommend,and why,or does it matter at all.The handbook states 5w30 oil conserving API SL.The UK dealer has apparently always serviced the car from new using Mobil 1 3000 X1 FE 5w30 but i will be doing my own oil changes,so have a choice as to what i will use.
What difference are you expecting between the brands if they all have proper specs for the application?
If you are in Europe, get any Longlife 5w30 VW approved oil. It is rated for at least 10k miles. I think Mannol Energy LL is 504/507 approved.
