Hi all,
Wanted to get some thoughts from you, I have a 65 GTO with a 505 CID aftermarket Pontiac engine, aluminum heads and a mild solid roller (242 @ .050 on the intake). The builder prefers a 15w40 such as the Napa, Valvoline, or Rotella. The lifters are Isky "EZ Roll" which means they have a bushing instead of a needle bearing.
The car will see significant street use. I have the idle set at about 1000 RPM now to try and keep the roller lifters happy. I spoke with Isky and they said they'd prefer to see me run a 10w40 to keep the lifters happy, I guess they want to make sure the oil gets to the top end especially on cold startup.
Am I just splitting hairs here, and is either a 15w40 or 10w40 going to be fine? What do you think?
Thanks,
Steve
Thanks,
Steve
