oil question (10W-30 or 10W-40?)
Pullman WA
I think I would like to avoid putting 5W-30 in this particular car, it starts fine right now using 10W-40 and it's in the 20 degree range here in eastern Washington state. Maybe I'll try
10W-30 next time.
A 10w-30 will not give you an improvemnt in cold start over a 10w-40.
It is the first number in a viscosity rating that indicates cold start ability.
And both are a 10w-.
So if you want improved cold start a 10w-30 will not give it to you, but a 5w-30 will.
(Of course if you were running a full synthetic oil you could stay with a 10w40 even thru the winter.)
Fred...
10W-30 next time.
I agree on staying away from the 5/30 if possible.
Look at some of the data sheets at the various company sites,some 10/30's pump easier when cold than others. Actually some pump as well as some 5/30's,,just have to cruise the sites and print the data.
One could, theoretically, get a slight cold temperature pumping advantage with a 10W30.
In addition, you would have less VII's to shear back and thicken the oil.
I agree that generally a 10w-30 is a allround better grade (due to less VI's used), and also that some 10w-30's exist, that pump better cold than some 5w-30's, (I didnt wanna complicate my original reply).
But in general for winter drving most 5w-30's will pump better cold than most 10w-30's.
Fred...
In an older economy car that recommends 10W-30 or
10W-40 year round which is the better choice during the winter? The car is a mirage with 158,000 miles on it. I've been using 10W-40 all summer, but noticed that 10W-30 can used pretty much anytime of the year too.
I agree with Palmerwmd. In most cases a 10W30 is a better all around oil than a 10W40 IMHO. Dependig on the severity of the winter, you could move to a 5W30, but wonder about the thinness of the oil in a car that old.
Quote:
'Dependig on the severity of the winter, you could move to a 5W30, but wonder about the thinness of the oil in a car that old."
If very very cold no problem,that oil will be pretty thick I believe even when driving for short distance because of oil temp. Take some 5/30 dino and get it to 20F somehow and pour it into a container,glug glug,
