Oil qualities influencing your decision to buy
WA
What's are the top 3 parameters you may consider (if any) when selecting an oil. For example any of the following: base oil category, noack, kv100, hths, tbn, vi, tan, flash point, ccs, mrv, pour point, uoa history, certain additives or lack thereof (published or based on voa), kv40, price, brand, container (design, size, color), local availability, ...,etc. Any final deciding factor (top 3) once you have decided the grade and spec (ilsac, acea, etc.)? I know you may have cars that are under "oil is oil" category shocked2 but I am sure many (if not all on bitog) have cars that ain't grin2
Kansas
Redline oil because it's a POE and it flows super well in hot and cold temperatures. It is overkill and has tremendous advantages over the other bases. Esters have stronger film strength and a hths of 2.9 from the 0w20 is nuts. Viscosity is compared to 5w20 /5w30.
OilUzer
WA
So your top 3's are: base oil, hths and mrv! Solid top 3 grin2
ZeeOSix
$100 site donor 2022
PNW
HTHS Noack dexos1 Gen2 I bought Valvoline Advanced 5W-30 based on those parameters. Bonus was the easy pour 5 qt jug ... works really well.
'Stralia
A3/B4, ACEA C3 (depending on application) Dexos 2 Low Viscosity Index (if I have a data set, Harman Index closer to 1)
Taiwan
Availability (otherwise, what's the point?) Viscosity. Nothing lower than 10W30 and in practice 15W40 is a working minimum. Additives (old school Zn levels favoured, so nothing newer than SJ). Brand : I have to have heard of it. That doesn't mean YOU have to have heard of it, so China Petroleum Corporation stuff is OK. Price: Around 100NT /litre, give or take. This doesn't tend to get you stuff labelled "synthetic", which is OK by me.
Minnesota
1. Consistent availability (not just at my local walmart) 2. Meets specs (in my case D1G2) 3. I can get it for a decent price (roughly $5 a quart)
FCD
Mallorca, Balearic Islands, Spain
Price HTHS of at least 3.5 TBN of 10 or more Low NOACK if possible. Preferably >1100ppm of Zinc / Phos Basically i look for ACEA A3/B4 on PCMO's or API CJ-4 or older and ACEA E7 on HDEOs
JAG
Fredericksburg, VA
All viscometric data Synthetic with some Group 5 present TBN > 8 Zinc between 750 and 1200 PPM Molybdenum > 100 PPM - much more if not trinuclear Mo Sulfated ash < 1.2% Volatility < 10%
Illinois
40 years of using M1 oils with never an oil related failure such as sludge, varnish, engine wear that could be detected, increased oil consumption, and all at 10K OCIs. All of the other stuff is for others to fret over.
