i see no one is going to question mr adibigs reason for switching to a larger oil filter, i.e. increase oil pressure.
a physically larger oil filter with the same media material allows but does not guarantee more filter material inside thus more dirt capacity before plugging
a larger sized filter may actually reduce pre filter pressure if there is media flow resistance in the OEM size filter.
playing around with filters not spec'd by the engine manuf. can cause oil flow restriction, media breakdown and oil gallery plugging, leaks and lose of oil due to seal failure, ad naseum.
flow rate is at least as critical as pressure.
i would suggest a course in fluid dynamics.
a seized engine is not a pretty sight, more scrap for China.
