In a typical gas engine journal bearing oil is under pressure on one side and the other generally has zero pressure. In fact no pressure is needed at all on any end. If oil was just dripped onto the side of the bearing it would be taken up into the space by capillary action. A bearing partly under an oil bath or oil splash will take up oil by itself.
Many electric motors have a thick felt oil reservoir that merely holds oil next to a sleeve or ball bearing. There is lubrication but no pressure. If somehow you pressurized the bearing there would be no additional force of separation between the journal and bearing surface, none.
The innate oil properties are solely responsible for the lubrication effects. The pressure is there to deliver oil and to create flow. This allows for the other function of oil in SI engines, that is to cool the bearing. Only flow can provide this function. Also, only the flow of oil increases the force of separation in a bearing. Pressure has no effect at all.
Oil pressure is insignificant to the fluid pressure, the force of separation in a bearing. The fluid pressure may be several thousand PSI. An oil inlet pressure of 50 PSI increased to 90 PSI will have NO effect.
Doubling the flow however will have numerous effects. The force of separation is directly related to the flow. Increased flow will cool the bearing and cooler parts wear less. If you increase the flow, even with a decrease in pressure, you will increase the force of separation in the bearing. If you cool the bearing then a thinner viscosity oil, thinned less than by a hotter bearing, will have the same oil film thickness.
The biggest misconception in motor oil is that pressure equals lubrication. This is the opposite of the truth.
aehaas
aehaas
