Originally Posted By: SteveSRT8
When you changed the cam was the timing gear set and chain done too? Many of my Mopar 318/360's in my fleet back in the day would puke bits of plastic that would clog the screen of the oil pickup. Oil pressure drop was obvious.
FYI, Steve, the Magnum version of the 318/360 never used a nylon coated cam gear. Its got a steel chain (non-roller) and steel gears. It'll get loose enough to make the cam timing sloppy (crank-triggered ignition keeps the spark stable, at least) but in my experience its like a Ford Modular- at multi 100k miles the chain will get so loose that the engine will barely start due to retarded valve timing, but it'll never jump like the old plastic covered cam gears would.
