I replaced the oil pan gasket (RTV) recently and had the opportunity to have the first look at the bottom of the motor. For the most part, the motor was very clean with no new deposits and I noticed some old carbon deposits had peeled off. However, when I looked at the pickup screen, it had a pinch of debris still attached. I took it off the screen and had a closer look at it. It was a clean oily glob that consisted half of bits of RTV and the other half of paper fibers. Considering that the FF filters that I use are also made of paper, could the paper debris be due to the FF filter? Is there a moral to this story?
I have had a bypass filter on my '95 Saturn and religiously change the TP rolls every 2-3k miles. For the last 27k miles I've only done one oil change. The bypass filter is a Gulf Coast O-1 Junior and I use Mobil 1 oil. The engine runs fantastic and I believe that it's burned an insignificant amount of oil for the entire time the BP filter has been installed.
