Oil or additive for valve leak
ga
My wifes Chrysler cirrus is leakin from the valve cover gasket(it is putting oil on the spluds. What is the best solution besides changing the gasket. Is there a good additive or oil I should switch to.
Thanks !
Now that I have deciphered what you are trying to say, I think your saying the valve cover gaskets are leaking and you have oil on your sparkplugs. You need to replace the valve cover gaskets and the sparkplug tube seals. This is an inexpensive fix doable by you.
