https://jalopnik.com/the-fascinating-reason-why-nascar-engines-run-so-hot-1835071544
The Fascinating Reason Why NASCAR Engines Run So Hot
The average car on the road today keeps its engine running at around 200 degrees Fahrenheit, but a NASCAR racing engine runs around 280. Here's the reasoning behind this, why teams run ice-water through their engines, and more fascinating facts about NASCAR engine cooling systems.
{ SNIP }
As far as the current setup, which incentivizes cooling system compromises in favor of drag reduction, Randolph admits that it's a "reliability issue," and that it's expensive to design an engine to handle those elevated temperatures and pressures. In an email, he described how much stress those conditions put on engine components, saying:
Components that suffer from high temperatures include
rod bearings (oil more likely to cavitate as it gets hotter),
pistons (aluminum softens as the average operating temperature increases),
valve seats (seat wear/erosion proportional to operating temperature), and
cylinder heads (life shortened due to aluminum softening).
Lubrication becomes problematic as oil film thickness reduces with temperature and in fact the oil itself begins to dissociate above 350F (engines smell like sulfur when disassembled due to oil dissociation).
Bore roundness deteriorates, bolt clamping forces change (some increase, some decrease), chances of knock and/or preignition increase. Lots of bad stuff.
To help increase engine durability, Randolph says his teams uses special coatings, alloys, and sealing materials.
And the cooling system uses high-temperature o-rings and threaded connections in place of rubber hoses.
But of course, this all adds cost.
Stephen Papadakis, the owner of Papadakis Racing and the subject of our story last year on the early tuner street racing culture of Los Angeles, also runs an excellent YouTube channel that provides all sorts of insights into race car technology. In his latest video, "7 Things You Didn't Know About NASCAR Cup Technology," he gets into some hot, steamy NASCAR cooling system details:
