I am fairly new to this site. I am wondering how long should oil last with a bypass filter? Is it true oil does not wear out, but the contaminents are why we have to change it? Theoretically, can one run oil forever if it is filtered properly?
No ...but that doesn't mean that tp is a bad thingquote:
Has nothing to do with a TP filter.
Is this a anti-tp thing?quote:
But in the end, you still have to change filters, I don't care if it's a piece of "sh*t paper or any other material.
quote:
The oil has to be suited to the engine/service duty. Naturally UOA is recommended by many to determine if all it going well in any extended drain situation.
John, I tried searching for the "blotter test" through google to see exactly what it was a while ago and couldn't find it. Is this basically putting a drop of oil on a piece of paper? And would the particulates make the edges of the drop darker or the center of the drop? This would be analogous to a coffee stain on a piece of paper, right?quote:
Originally posted by John W. Colby:
The blotter test appears to be a measure of particulates in the oil. The reason this would be useful with the TP bypass is that as the TP filter begins to clog, the quantity of oil through the filter should begin to drop and therefore the particulates should start to rise.
I have a 6.0 PSD and have gone 5K miles w/a Frantz. The Frantz canister still gets as hot at 5K miles as it does when a new roll of TP is installed.quote:
Originally posted by Gary Allan:
Here's a UOA that may interest you. It appears that this member is using his MG for longer drains. 5k is a little more in line with a synth's inherant longevity. 5k on tp and still warm
Aside from those towing or racing (or being "spirited" in driving style), the problem most oils see is never heating up enough. Studies have shown that the total warm up time for the engine to reach full thermal saturation is about 15-20 minutes. Most driving events don't exceed that by much on a daily basis. I didn't believe this at first when our membership asserted this ..it was then confirmed by a study quoted by the good Dr. Haas (AEHaas)quote:
oil coolers aren't mentioned.
Do you get better oil analyses compared with not using an oil-to-coolant cooler?quote:
The oil coolers that use the cooling system (liquid/oil) are the best, since both the coolant and the oil are at their optimal at about the same temp. They tend to buffer each other a good bit ..smoothing out the spikes.quote:
Air exchangers, without a thermostat, aside from being less efficient - will exacerbate any moisture retention ..fuel ect by delaying any purging via evaporation. So unless your routine daily drive is of a decent length to compensate for the cooler oil temp when unstressed ..you're merely adding to the problems that shorten its useful life.
The liquid/oil cooler are a good thing. I use them on my jeeps and am trying to adapt this unit from a Crown Vic on one of my vehicles
