Looking for some help on pinpointing an oil leak. This is on my milan with the 3.0 duratec engine.
I noticed the pulley on the drivers side of engine that drives the waterpump had a light coating of oil on it about a week ago. I cleaned it off. Last night I checked it again and the oil coating is back and oil appears to be lightly "spraying" around from the pulley now. There's a line sprayed onto a nearby hose that is in line with the pulley.
Is there a seal for the camshaft that could be leaking? Just wondering if there are any common leak points for this engine. I will have more time this weekend to look at it and post some pictures.
This car has always been changed regularily with conventional. Was always taken to oil change places for the first 50k - who knows what they used, then I began changing it with 5w20 conventionals. This past fall I changed it with Mobil 1 0w20 before the cold winter. Could the Mobil 1 have done a little cleaning and caused this leak? The engine has always looked spotless through the filler hole and is at 75k now.
