The oil gelling or sludging was in the 1997-2002 Toyota & Lexus vehicles with the 3.0 liter IMZ V-6 and 1997-2001 vehicles with the discontinued 5SFE 2.2L 4-cylinder.quote:
Originally posted by kreativ:
There's been talk of oil gelling issues with the '9x-'02 Toyota V6 engine.
Of the manufacturer recommended conventional oil weights of 5W-30 and 10W-30, would one of them be less likely to cause this problem?
The one in the Camry still has 87 octane being the one recommended. The one in the Lexus ES (same engine except with VVT-i) has 91 octane being the one recommended. The compression ratio is the same though (10.5:1), so I haven't been able to understand why the Camry V6 and the ES would require different octane gasoline.quote:
If you own this engine, as I do, also recall that it is designed to use 91 octane fuel. Using lower levels can exacerbate the problem, through higher cylinder head temps and poorer exhaust gas profiles.
Originally posted by TooSlick:
....I'd use a 10w-30, Group II basestock with perhaps 100-150 ppm of moly in it ....
Interested in how moly could be of a benefit in these circumstances?![]()
[QB]Kreativ,
I hope I didn't go overboard on this Toyota engine issue ...The engine is very smooth and makes lots of power, you just have to do more frequent oil/filter changes. Toyota also makes an excellent automatic transmission and very reliable electronics ....
These engines are almost perfect if they are serviced as needed. There are almost no head
gasket problems with them due to the all aluminum
design, and the wear rates shown here are quite low, so they should be long lived.
They are just not very kind to their oil, and it therefore needs to be changed more often than what is typical.
Your careful experiments that you and others have posted here have been helpful. Thanks!
