I bought a 02 dakota quad cab 4.7 that a dropped valve seat. While replacing the seat, I saw one of the cam bearings was badly galled. The guy at the machine shop said that's common on this engine, and recommended replacing the cam but not doing anything about the aluminum bearing in the head (its not a replaceable bearing). So that's what I did - just replaced the cam.
Current oil is 5w30. At hot idle, I hear a rocker chattering, which I've read is common on this engine.
I don't think it uses oil, but I'm not sure since I've only put 1k miles on it since fixing it. It has around 175k.
I expect to put 2k on it per year, doing stuff like: taking jet ski to the lake, hunting, driving in bad weather/snow, whenever I need a truck.
I'm thinking about 10-40 or 15-40, to see if that helps the noise. thoughts?
