dx92beater
First it is WD40 now it is 40w-70. Make up your mind.Nulon 40W-70?
You never joined the 800 mile club on the ALH TDI? I did it on 5w40 HDEO.
But I had the 5-speed manual back then.
Seriously, thinner oil won't get you to the fuel economy of the 5-speed manual.
I'm not sure about lying, just probably misinformed.Did anyone actually look at the link I posted in my original post for user AZsynthetic?
Was he lying when he says that he obtained much more MPG than just 1mpg by going thinner?
Well that or needs a good math refresher course. You'll get better MPG by increasing your tire pressure 4 or 5 PSI. In all the years of fooling with thisDid anyone actually look at the link I posted in my original post for user AZsynthetic?
It's the valve bodies on these. The job isn't actually that bad even for a slow old turd like me. A synthetic with low cSt. Even Maxlife is not as thin as the original.Change transmission fluid early with good quality synthetic. That will go a long
way to keeping the transmission parts inside the case.
Points taken.I'm not sure about lying, just probably misinformed.
If you look at the expensive details that auto engineers add to a vehicle striving to meet CAFE requirements, then you would understand that any "magic" lube would be greatly appreciated and accepted by them.
Somewhere along the line, probably due to marketing, the term "synthetic" became synonymous with efficient. Additives and base oils are two different things and viscosity is viscosity.
Hahahahaahahaha! Funny you mention it. I just switched to 0W-20 M1 AFE on my 213k 2nd gen Prius. No appreciable gain. It's probably cause my wife uses the car for a trash can and is loaded with starbucks cups and McDonald's bags though.Well that or needs a good math refresher course. You'll get better MPG by increasing your tire pressure 4 or 5 PSI. In all the years of fooling with thisI've never seen an oil increase my MPG and early on some of them claimed as much as 15%. Lots of AG's should have been bringing lots of consumer fraud cases against them.
Yah those Starbucks cup are good for at least a minus 2 MPG.Hahahahaahahaha! Funny you mention it. I just switched to 0W-20 M1 AFE on my 213k 2nd gen Prius. No appreciable gain. It's probably cause my wife uses the car for a trash can and is loaded with starbucks cups and McDonald's bags though.
I'm fairly certain that it will destroy every seal it touches.if you’re willing to go all out, mobil jet oil ii is $25/qt. [email protected] of almost pure ester, very close to 0W8 being developed right now
The intent is to be a braggart even if it doesn't make financial sense. Instead of look at my burnout and my quarter mile time (neither of which make financial sense either) I want to shift to something new. I have other vehicles for that sort of duty. I guess you didn't look at my previous posts. What is it with people not reading the entire thread these days?Fuel economy? How rich can a guy get with an extra 2 bucks?
