Newbie forum member and a lifelong auto data junkie. I’ve learned enough from BITOG to be dangerous, and I’m a long-term synthetic oil advocate.
What’s a good synthetic oil for the 2.0 turbo, direct-injected motor in my new Kia Optima that I plan to keep well beyond the warranty? I’ll stick with 5K oci to maintain the 10 year/100K warranty, and get UOA’s from Blackstone periodically. The manual specifies 5w-30 or 5W-40, SL, SM or above; GF-3, GF-4 or above; ACEA A3 or A5, and says: “Recommendation: 5W-30 ACEA A5”.
My typical commute is 17 miles each way, 50/50 mix of city and highway (25-35 minutes), and this is our weekend/long-trip car. I don’t drive hard or use high revs often, but appreciate the turbo power advantage when “needed”. Previous car was an Audi A3 with the 2.0T FSI motor. Blackstone's UOAs with M1 0W-40 in that car recommended a 6100 mile oci, but I was adding 3 qts between changes, thanks to the poor PCV system in that early DI motor.
I want to do what’s possible to reduce intake valve deposits and protect the turbo. Better gas mileage and less expensive oil are nice, but engine protection is a higher priority.
My short list of readily available, acceptably priced (to my wallet) oils (pretty much everything is available here in Seattle):
- RL 5W-30 – Is it GF3, 4 or 5, and what’s its ACEA rating? Is it worth the extra expense with 5K oci?
- M1 0W-40 – frequent BITOG recommendation for turbos and high specific output engines, but not GF rated.
- M1 5W-30 or 0W-30 AFE – Meet all the recommended specs, but would 0W-40 be better?
- PP or PU 5W-30 – Do they meet ACEA A3 or A5?
Related questions, particularly with 5K oci and the features of this type of engine:
- Is low NOACK important to reduce DI valve deposits?
- Redline doesn’t use any VII. Is that a benefit to DI valves, as stated in the Pennzoil FAQ?
- What's the significance of high VI, TBN and low NOACK data?
- What HTHS is needed for long engine and turbo life?
- How important is base stock, or does the specific oil data describe what matters?
- Is lighter oil better for my use and oci? (I read Motor Oil University twice and that’s still not clear.)
- Am I over-thinking this? (But this is BITOG!)
