Oil for Eaton Supercharger
GM stinky stuff
Bell Performance have something.
There's a GM TSB that says to use 5W30 M1
I use Castrol Edge 5W30 A3/B4.
Would be inclined to use Penrite SAE30, which is dual use gearbox as well.
I think you could go to a Ford dealer and buy the supercharger oil for a 2001-2004 Ford Lightning F150, 2003-2004 Mustang Terminator, or a Thunderbird SuperCoupe. I think those were Eaton superchargers, but I am not totally sure.
No one ever got in trouble for buying GM supercharger oil. 2 bottles @ $10/ea every 50,000 miles.
Make sure you check the level periodically. Had a customer never check the level on their Lightning and ran the supercharger dry. Was a very expensive failure for them.
Thanks guys, this was a supercharger on a 350z a friend just picked up, rebuilding this motor is surprising easy....first Japan motor for me
Mobil 1 5w30
Go to the GM dealer and buy supercharger oil. The Eaton supercharger timing housings only have gears in them, and the oil is never exposed to products of combustion, so a gear oil is appropriate. This is why the stuff should stink like a gear oil. Later model Eaton's went to 83-tooth timing gears to deal with noise complaints, and the large number of fine teeth turning at 12,000 rpm make them excellent for shearing the oil.
I agree that the right stuff is the right stuff.
But when I got my L67, local Holden dealer hadn't bought a bottle in 12 years, and it took them 2 weeks and $50/bottle to get, meaning that GM-H aren't stocking/shifting it...either the S/Cs are running on something else, or they are still factory fill.
