Hey guys, I thought I'd ask around in here first about oil before I went out and bought any, I have a few questions in any case:
1) What would be the best oil for an engine with roughly 215K miles on it? I know that I'm not supposed to put sythetic into this thing since it's been running on regular oil for most of the time and I don't want it to start leaking or getting blowback. (the engine is a twin cam aluminum block saturn engine, 95 SL2) I found quite a lineup, among the oils I found readily available were: Castrol GTX and startup, Exxon High Mileage, Havoline, Motorcraft, Quaker State and Valvoline, all these oils are 10W-30. There is currently castrol GTX 10W-40 in there.
I would seem inclined to go for the Valvoline or Exxon oils right now
2)why is it that almost no high mileage oils are Energy Conserving? (the Exxon high mileage is the only one I've found) A guy at napa told me that as long as the oil has the same weight and api rating there shouldn't be any friction difference between the two.
thanks for all your answers in advance,
D
