My girlfriend drives a '98 Prelude with the H22A4 engine. This engine burns oil. Yes, I know there are people out there who have H22As with 10 million miles and have never burned a drop, but in general, most H22As burn oil. My girlfriend's car is no exception; it uses about 1qt/1000mi. Hers has about 120k miles on it.
I believe most of the oil being burned is getting past the rings. This seems to be typical of these cars, and I see no puffs of smoke on deceleration or startup, so it's probably not the valve seals. These engines have notoriously large clearances on the rings, and they have the FRM cylinder liners which some suggest may tend to trap oil.
Given that oil is getting past the rings, what oil is good to use for minimizing the burn-off? I assume we want (1) a heavier oil, (2) an oil with a higher flashpoint, (3) an oil with lots of moly, (4) anything else?
Given these criteria, which is a good oil to use? We're in Boston, and I'd like to stick with a 5W-30 for those cold nights (or a 0W-30, but GC is a bit expensive for a car that burns this much oil and has its oil refreshed this often anyway).
Also, any idea on whether an Auto-RX treatment would be of any help? The car has always had regular oil changes, but usually with dealer-supplied bulk oil. I don't know how likely there is to be sludge. I plan to send off a sample for analysis when I change the oil, but I'm trying to figure out what to put in there in the meantime. We've got some Castrol Syntec Blend 5W-30 on hand.
Thanks for any thoughts,
Matt
Matt
