- Messages
- 80
- Location
- Rockledge, FL
It calls for 5w-20 but I been running Amsoil 10w-30 in it. I thinking it's a bit heavy for this engine. Is 0w-30 better or something else?
Quote:You're not hurting anything running a full synthetic 10W-30* in your engine. With your climate (especially if you "get on it" periodically), you're probably doing your engine a favor. Don't change a thing. *Synthetic base stocks have naturally higher inherent viscosity indexes than Group I & II base stocks. That advantage means they maintain an acceptable viscosity range over broader temperature variations with less reliance on viscosity index improver polymers.
Quote:From this thread: http://theoildrop.server101.com/forums/showflat.php?Cat=0&Board=UBB1&Number=727855 My
I am using these: 5W-20 Red Line in my twin turbo Maybach 57 with over 600 BHP 5W-20 Red Line in my wife's Lamborghini with over 600 BHP aehaas
Quote:Goes to show how much better Honda/Acura engines are compared to German engines.
so I called Acura Customer Care and stated sorry I didn’t buy a BMW 330i as I felt at lease German's called for oil.
Quote:What are you trying to say here?
... so I called Acura Customer Care and stated sorry I didn’t buy a BMW 330i as I felt at lease German's called for oil.
Quote:Smart man here.
If your engine specs 5w20 run it and run it as hard as you like.. You are not going to hurt it. You should run the lightest grade recomended and be happy you don't have some poorly machined engine that requires heavy oils to make up for poor manufacturing.![]()
Quote:Why do Toyota, DC, GM and Ford use it?
IMHO, Acura / Honda uses 5w-20 for CAFE.
