oil for 3cfm vacuum pump
JHZR2
Staff member
New Jersey
hi,
Im running a 3cfm vacuum pump in my laboratory for filtration purposes. It works great, but I can tell that the dino ND vacuum pump oil is vaporizing a bit when it gets hot and Im pulling 30 in Hg on the gauge...
Is there a decent vac pump oil (preferably synthetic) that is reccomended? Is compressor oil the same thing?
Thanks,
JMH
Hit button to soon a PAO would have a lower vapour pressure than a mineral oil blend, most vaccum pump oils are as I said straight run try as heavier vis a ISO 100 or so that may help or look up in the lab supply houses vaccum pump oil.
bruce
You might also want to open the ballast valve for an hour or so if the pump has one. What's the actual problem? Back streaming? I assume this is a rotary vane pump? No way they'll do better than a few millitorr and then only if they're two stage. 30 inches? Not on this planet, not even with a cyro pump
Thanks all! THere is a schaeffer's product that looks good for this duty... I just want good life without all the oil vapor smell in the lab...
JMH
Quote:
Our AC vacuum pump uses Mineral oil. The old R12 oil. I tried Pag and Ester once and it foams real bad.
ouch ! the moisture levels in a PAG or POE refrig oil would be horrific in a short time in a vacuum pump application. Ever drained the oil out of a compressor that has been open to the atmosphere ? It can look like a heavy ale due to moisture loading.
I used to use Suniso 4GS in a pinch when I was short of vac pump oil (IRRC the vac pump oil was an ISO 68 fluid) but it was changed out ASAP (usually after one use) due to concern about moisture.
Back in my lab days (I was a chemist in a former life), we stocked 2 types of vac pump oil: Fomblin, and no-name stuff our stockroom purchased in 55 gal drums.
Pumps in critical applications (or attached to high-dollar equipment) got Fomblin. Everything else got the bulk oil.
This is a rotary vane pump, yes? If so, then absolutely stick with oil spec'd for vacuum pumps. Your pump's seals will thank you.
If you're having a misting problem, then you need to install an oil-mist eliminator on the exhaust port (about $100 from a vacuum supply house), or alternatively run a hose from the exhaust port to a fume hood. In one of our labs with a pump that ran 24/7 in a fixed location, we run a 1-inch-diameter piece of PVC up the wall, through the ceiling tile, and tied it into the fume hood exhaust duct. We then just ran a short 3-ft hose from the pump to the PVC.
Just thought i would bump this up as i need to replace
the oil in my J/B Industries FastVac DV-200N 7cfm 2 stage
Vacuum Pump, could a guy use Amsoil's ISO compressor oil?
i do not want to mess this very pricy pump up so i want the right
oil..
JB just specs their oil as "highly refined mineral oil that should be changed after each use for optimum life."
my guess is that it is nothing special and amsoil would work great.
Thanks Tom.
Pablo whats your thoughts on this??, i need this pump so i
need to pick a oil. can amsoil's commpresser oil be used
in this??
I would call some local A/C supply houses and ask what compressor oils they carry.
You'll probably find a few that carry Robinair vacuum pump oil. I've used it in my Welch Direct Drive that I use on automotive A/C systems and it works fine, so long as you change it at fairly short intervals.
I have some specs for the Robinair 13204 somewhere on my computer if you want them.
Thanks, pm me with it if you can..
pab was of no help
....(lost a sale),so i just bought a gal of Robinair oil off ebay,
pumps works great..
