Patman
Staff member
- Messages
- 21,989
- Location
- Oakville, Ontario
It would most likely void the warranty. Best to stick with the 5w20 for at least the first few oil changes.
quote:It won't void the warranty. But the only way I'd use Syntec 0w30 is if it's the "Made in Germany" stuff that's just now showing up in stores in Canada. If it were mine, I'd probably run the new Mobil 1 0w20 due out next month.
Originally posted by rick: The manual calls for a 5W-20 weight all year round, would using the Syntec 0W-30 all year round on this car be ok or would it void the warranty?
quote:For the warranty to even become an issue, the engine would have to suffer a failure of some sort and a warranty claim would have to be made. The burden would be on Honda to show that the problem was oil related, and they would further have the burden of proving that the specific oil used at the time of the problem was the proximate cause of the failure. All this would be predicated on them establishing that the oil wasn't actually 5w20. Once they've done all that, then and only then would the warranty be void.
Originally posted by Patman: How do you figure it won't void his warranty to run 0w30 though? I thought Honda was very strict about using 5w20/0w20 ONLY with no exceptions?
quote:What does the new bottle look like? Is it silver like the European bottles?
Originally posted by Quick_lude: Rick the reason people are saying "no" to the Syntec because most likely you are referring to the black bottle, made in Canada stuff which afaik is a Group III synthetic, not a group IV. Since the cost is similar between the two I'd use Mobil 1. If you can buy the new bottle design Syntec that is made in Germany then you are getting a group IV synthetic and your moneys worth. Imo.![]()
quote:If you're talking about the "Made in USA" Syntec, I agree 100%. The German 0w30 is something else altogether. Read the thread on that stuff and look at the specs. This is one impressive looking oil.
Originally posted by 2K2AcuraTL: My .02c worth... Castrol syntec is in the same boat as Fram Fitlers..... ...nuff said![]()
quote:Nope, same black bottle, but it just has the new labels on it. The 0w30 part is in red instead of yellow.
Originally posted by G-Man II: What does the new bottle look like? Is it silver like the European bottles?
quote:Fair enough.. I'll have to keep an eye open for this oil then...(wonder if its available Canada..??)
Originally posted by G-Man II:quote:If you're talking about the "Made in USA" Syntec, I agree 100%. The German 0w30 is something else altogether. Read the thread on that stuff and look at the specs. This is one impressive looking oil.
