Originally Posted By: SilverC6
Without the magnet, wouldn't the ferrous material large enough to damage an engine just collect in the filter media anyway?
When I posted the Driveworks cut open above, Jim Allen posted some great details on the topic (copied below). Personally I wouldn't lose sleep not having one.
Originally Posted By: Jim Allen
What I always wonder about magnets is how much of the stuff that attaches to the filter wall would have been caught in the filter anyway. Plus, the amount of ferrous metal in some engines is a very small part of the total contamination. Is it really worth the money to re-address something the filter is already addressing?
As a group we are generally agreed that within the "normal" threshold of full flow filtration efficiency, the differences in wear between "normal" and "high efficiency" filtration is small. Using that argument, some considering spending more than $5 on a filter a serious waste. They would also say spending the extra money for a Filtermag or somesuch. I essentially agree but will go with the highest efficiency filtration I can find within a reasonable-to-me cost basis. No engine ever died from oil that was too clean, after all.
Filtermag has an interesting analysis posted (go here:
Report, showing a big drop in small particles. Note also that when you look at the UOA that went with the really good particle count the wear spectrographic wear metals don't look much different than the others that didn't have the Filtermag. Does that mean the Filtermag had no appreciable effect on wear? I put another magnetic product on two of my tractors and sent the oil thru similar analysis and got similar results. My particle count wasn't nearly as good as the one the Filtermag shows but the UOA wear metals were essentially the same leading to the impression at least that it had little effect on engine wear.
Anyway, two oil analysis and PCs don't prove or disprove the concept. I can see the potential value in it with some engines that normally shed a lot of iron... old school flat tappet, pushrod engines with Morse timing chains mostly. Most iron comes off the cam of a flat tappet engine, the Morse chain and rocker arms. A modern roller cam/rocker engine with a lot of aluminum parts and a belt-type external timing chain would probably NOT be a good ROI candidate for the extra expenditure due to not having these iron shedding parts.
