Googling that specific filter, appears to have no flutes on the end/dome, so fitted cap wrench a no go. Using specs on Amazon, it shows 3.66" wide, OD. So, you'll need a wrench that opens that wide. Any strap or claw type with that opening in range will work. The Lisle 63250 cam action 'wide range' filter wrench should work. I own the smaller import version, works well.
