- Joined
- Apr 14, 2022
- Messages
- 1
I have a 1937 Hudson 6 cylinder engine which I’ve rebuilt a few years ago. There is no filter system & since I’m running modern detergent synthetic oil, I’m looking at adding a filter setup. The engine is a splasher & the oil pump pulls oil from pan to splasher tray which is run off the cam. I’m told the oil pump is around 5 pounds pressure. I’ve been looking at both a bypass vintage type setup as well as a full flow system.
Anyone have experience with adding a filter, especially a full flow setup? I’m guessing I may need to contact a filter manufacturer to see what flows the best & least restrictive.
