Basically API SF, so looks like anything with the latest API rating in the right viscosity would work in this vehicle.
I'd like to see a larger more clear shot of that viscosity chart ... looks interesting.
You can not judge an oil by feel!Hi,
I am a new member of the forum. I've got a question which really made me concerned. I've recently changed the oil of my E34 with Unil 10W-50 (feedback for the brand would be much appreciated as well). When I researched the brand, I didn't find any negative comments and I had 5 liters laying around, it meets specs, that's why I used it. Now, whenever I pull the dipstick the oil feels very thin. Like as soon as I pull it out, oil drips. In my experience, it takes a second or two before a drop forms and falls.
Engine has no issue whatsoever with mixing coolant and oil, level is fine, color is sort of gray though. (I may attach a picture if needed).
Now what concerns me is: Is oil thickness (judging by the dipstick) a good metric of oil quality? Am I overthinking this? The engine works good, no ticking and has even become quieter since I changed the oil.
I would really appreciate your feedback, cheers.
The viscosity chart and required API rating in his owner's manual?Yes his vehicle predates Longlife-01 just as it did for my E34. However it is still the correct oil for that car just as it was for mine since “Special Oils” went to Longlife-98 then to Longlife-01.
Besides it was the OP s who noted the oil he was using “meets specs”, so what “specs” is that oil meeting if it isn’t Longlife-01?
I'm not certain if you can "feel" a difference in viscosities as measured by rubbing the oil between your fingers for instance. However you can see a difference visibly by how oil behaves in a drain pan for instance, or by dripping off the dipstick.Which 10W-50 has the required BMW approval?
And feelings are useless in this instance.
Yes many posters on here don't seem to know the difference between a grade recommendation in the manual vs. a specification, license or approval. I'll give you that.The viscosity chart and required API rating in his owner's manual?
A motorcycle example doesn't clearify anything, it's muddying things.
The bottle (clearly) states 'for BMW motorcycle engines', meaning it's
for BMW motorcycle engines only'.
This is not the product I poured, It is a Belgian brand: https://unil.be/en/products/engineoils/giv7-10w50-1474/.
Just guessing:
OPALPERF GI-V7 10W50 - Manufacturer of industrial oils and lubricants
Lubricant with remarkable performance: very easy cold-starts and immediate hot engine lubrication, optimum engine lubrication.www.unil-opal.com
This might be the 10W-50 he's running. A quick google search reveals that
Opal is quite popular in Russia and widely unknown or even unobtainable
in NA and most of Europe. No idea on their quality though.
On an M20 or M50 engine I'd probably run a 5W-40 (MB 229.5/LL-01/A40),
perhaps some 0W-40 or even 0W-30 during the colder season. Sibiria sees
temps as low as -65°C, which calls for a PAO 0W-20 or just letting the engine
run the whole night like some Russians in Nowosibirsk etc. use to do.
I wouldn't worry about it - anytime I do oil changes on Nissans (be it 5w30 or 0w20) the same thing is going on.Now, whenever I pull the dipstick the oil feels very thin. Like as soon as I pull it out, oil drips. In my experience, it takes a second or two before a drop forms and falls.
What specs are printed on the bottle?Hi,
Car will turn into a pumpkin if you run the not BMW approved oil.Which 10W-50 has the required BMW approval?
And my bad - by 'meets spec' I meant it meets SAE standard appropriate for the car. These engines don't want much in terms of oil, as long as the viscosity is right.
It's the same name (GI-V7 10W50) and the same wording including the 'molybdenum
and bismuth formulation'. So tell me why do you think these should be different oils?
Both sites even say 'UNIL' with the exact same logo. This oil is perhaps ok to use for
up to 10.000 km even though it lacks approvals. However I'd consider something else
for your next oil change. As I said before I'd suggest LL-01, MB 229.5 and Porsche A40
approved oils. 5W-40 seems ideal for these engines (M20 & M50) in almost all climates.
at -65c which is -85f, i'd run 0w5!. Sibiria sees
lol"Nah, I'll run 20w50 just because"
-BITOG forum
