Been using Redline 0w20 and have noticed it's quite a bit hotter during the drain. Coolant level is serviced regularly and was trying to think of why. Our master technician runs Motul 300V and noted the same instances. He comes to the conclusion that with the higher end oils they retain the heat better and by doing so allow the car to run cooler. It got to the point tonight that we were on the conclusion that since the flash point is higher it allows the oil to get hotter so the engine isn't absorbing as much of the heat. When I ran Castrol MAGNATEC it seemed to kinda do the same. Some have said the 0w20 MAGNATEC was a blend of 3&5 groups. Qsud and PU 0w20 didn't seem to flow out as hot no matter what. Just an observation. Any talking points or theories are always welcome. Good day everyone
