- Messages
- 69
- Location
- collierville, TN
Well in reply to my last post i think it is sensor related b/c i get 41psi on startup and it stays in that range for a while even after its up to temp.. Im thinking that i can add a high volume pump, oil cooler, and replace the rear main and run synthetic? I tried synthetic in the past (M1) and it leaked but dont have issues with Dino..... Any thoughts/comments? Engine run temp is 210 so im thinking oil temp is in the 190 range? Bypass it to keep it at 180-195? Main thing is the summers are really hot and id like to be able to hold more oil and be able to go longer between oil changes b/c ill be going off to college in the fall and will be in a dorm....
Ill also be installing a oil temp guage while i have the pan off ![[Smile]](images/icons/smile.gif)
