Hi Everybody,
I’m a long time lurker on BITOG. Nice site you’ve got here! I thought I’d introduce myself with a “what’s the best oil for my (wife’s) car” question.
Here’s the history. For the first 30,000 or so miles, her car was dealer maintained. Disclaimer: this was before she met me! From then on, I’ve been doing oil changes every 3,750 miles with Valvoline Durablend.
I’ve had no problems with Valvoline, but I’m thinking of switching to a high mileage oil, you know, one of those oils that claims to condition seals. I think they also have more detergents in them. Also, Valvoline seems frowned upon by this board.
I was thinking about Mobil Drive Clean High Mileage synthetic blend. I like blends, as I think the little bit of synthetic in them helps, and with 3,750 OCI’s, a full synthetic is a waste. A long, long time ago, on a different car, I switched from conventional to a blend and got a significant mileage increase. I’ve been sold on blends ever since. I like 3,750 OCI’s just to get whatever crud that has accumulated out of there.
But they changed the Mobil oil line-up. The high mileage oil is no longer a blend. The new line-up is shown here: http://www.mobiloil.com/USA-English/MotorOil/Oils/Oils.aspx
So now I’m thinking a 50/50 mix of Mobil 1 10W-30 and Mobil High Mileage 10W-30. They are both GF-4 oils. Toyota recommends 10W-30. That fits our climate and driving style, so I see no reason to change weights.
Thoughts? I suspect many of you might recommend staying with conventional, rather than the mix. I might be able to be talked into this. But I doubt I can be talked out of 3,750 OCI’s. Like I said, I like to get any accumulated junk out of there.
If the filter matters, I typically use the OEM filters. I get those dealer flyers in the mail, you know the ones, where they sell the 15,000 mile checkup for only $99.99 and all they do is change the oil and check about 30 things. They typically have coupons for OEM filters for $3.99. Can’t beat that!
Thanks for your time.
