If the car is driven enough each time or nearly every time it's run to get up to full operating temperature where it would burn off any moisture in the oil I see no reason to change it until it's recommended OCI. As long as the oil is just sitting in the oil pan I don't worry about it. I've got a '97 Ford that I use mainly for longer trips, I bought it new in Feb. '98 it currently has 41K original miles on it and gets an oil change every 5K miles regardless of whether the oil has been in it a year or 10 years. As for your generator if you're running it 30 minutes at a time that's plenty long enough to burn off any moisture in the oil. The oil I'm using in my cars has been in my garage for anywhere from about 15-25 years. I see no difference in the oil sitting on a shelf in a plastic bottle and sitting unused in the oil pan.
