“In your case I suspect most of that oil is being held in largely because of, among other things, the ADBV. Perhaps if you just put a nail up thru the ADBV enough to pry it open and let the filter sit - it would drain better?”
I suspect you’re right.
“… early 70s of AMC I-6 engines and mid-70s through the end of availability in the U.S. of the brand of I-4 Peugeot diesels. I owned examples of each.”
Thankfully, I have not.
--- Bror Jace
--- Bror Jace
