So, a 5w/30 acts like a 5 weight oil when cold,
No it doesn't. The first number is just a representation of how an oil will behave at a measured temperature which happens to be at -35C for a "5w". But it's a pumping viscosity, not to be confused with kinematic viscosity that is represented by the second number in the oil grade.
Saying that it acts like a 5 weight oil is inaccurate.
http://www.upmpg.com/tech_articles/motoroil_viscosity/
Read it again.......I don't think that article says what you think it does. It only acts like a 5 weight oil, when cold, as I stated. It may not be exactly like a 5 weight, but it is labeled 5Winter for a reason.
The number in front of the W is not a representation of an SAE 5 "when cold", which doesn't exist as a motor oil grade, neither does a 10 or a 15, all of which are a xW classifications. The same goes for a 0. Is there an SAE 0? No. The SAE grading system for oils under the non-W classification starts at SAE 20.
Just as an example here, Mobil 1 0w-40 and Mobil 1 0w-20 both carry the 0w designation. Which means they meet the cold temperature performance requirements for that classification. This classification is simply a set of limits for MAXIMUM viscosity at -40C and -35C respectively. That is the ONLY thing those two oils have in common:
M1 0w-20:
Visc@100C: 8.7cSt
Visc@ 40C: 44.8cSt
MRV@ -40C: 9,200cP
M1 0w-40:
Visc@100C: 13.5cSt
Visc@ 40C: 75.0cSt
MRV@ -40C: 31,000cP
Is 9,200cP close to 31,000cP? Nope. But they are both under 60,000cP at -40C (and under 6,200cP for CCS @ -35C), so they both get to carry the 0w designation. There is no temperature that M1 0w-40 is even CLOSE to the same viscosity as the 0w-20.
You'll notice the 0W and 5W designations have the exact same visc minimums @ 100C, with no maximums for 100C or HTHS. You'll also notice the distinct absence of an SAE 5, 10 and 15 grade on the chart
Those grades only exist as ISO hydraulic oil grades, not engine oils.
