The first thing I would make sure for them is to understand safety measures. Back up everything. Put car on jack stands and tires on rims below to back it up. I would focus on that before anything.
Their other car is a Toyota V6 with the cartridge oil filter and an oil pan where the quick lube has already semi-fubared the threads (I had to clean up the threads with a tap), so I think the RDX might be the better candidate.Nice engine to learn how to strip the drain plug on. First you better tech them how to use properly set and use a torque wrench.
Seriously these and a few other aluminum pans are notorious and will not take over tightening by very much. I use a TW on all aluminum pans regardless, pay close attention to the threads when you remove one that you didn't tighten.
General info. always use a quality torque tool of the correct size, do go go after a 18ft.lb bolt with the trusty HF 1/2" drive, its a guaranteed strip out. A 3/8 drive wrench 7-50 ft.lb would be ideal. If you are going to work with aluminum and most engine today use a lot of it these tools are a must have even for weekend warriors.
I do something similar. With 6 cars to change oil, I can't remember all the detail for each one. This way, everything is laid out at the onset. It saves from running back and forth.One other thing I do is I have a card for each of these occasional jobs (oil change on the Honda, oil change on the BMW, etc) with all the required tools, specs and supplies listed. That way I know what socket to use, which oil, how much, torque specs, etc. I don't start the job until I have it all there and I just find that makes the whole job go better.
Most of us on Bob have been doing it for years and have forgotten that a simple oil change requires all sorts of knowledge and mechanical skills. It's also a good place to start.
Michael, I have to call baloney on this... You are very well spoken and direct. You have no bias.I am not the best teacher
I’m not harping on fathers “job” but I certainly agree with wanting the father there, present, involved and engaged. I have safety concerns here.Isn’t it normally a fathers job to teach his sons such things?
Hey now, I just did that myself. In my defense, it was only the 2nd time I used it - I always used the simple, open catch containers. I can tell you that the top basin area in a Flo Tools 16-quart pan holds over 4 quarts !! I got lucky.You know the plug on the drain pans you need to remove so the oil funnels in? He left that in.
Sounds like it was a good success. Glad to hear.Thank you for all of the tips and valid concerns.
As some posters mentioned, it was impossible to teach the entire process (lifting, actual oil change, reset OLM, clean-up, etc) in one session. Lifting the vehicle, resetting the OLM, maintenance-related inspections and clean-up of the work area are items to be taught during a future session.
When the kids arrived with their father, I already had the vehicle lifted and supported with jack stands. I also had the passenger front wheel removed for improved access.
Prior to this session the kids watched the youtube video suggested by @JC1 that is specific to the RDX.
The kids were shown how-to and successfully accomplished the following:
Everyone had fun and there was zero mess made, which was very impressive. The drymate oil spill mat and the form-a-funnel really came in handy.
- Check the oil level prior to service.
- Remove the oil cap and dipstick prior to service.
- Verifying the correct parts prior to service (Quantity/grade/type of oil, correct oil filter and crush washer)
- Locating the engine oil drain plug and oil filter
- Draining the oil and removing the filter. My new form-a-funnel worked perfect for this vehicle (see picture).
- Threading on the drain plug without damaging the threads, plus torquing the drain plug to spec with a new crush washer. When we tightened the drain plug, we turned the torque wrench together.
- Cleaning the filter mounting area and properly tightening the new filter.
- Adding the correct amount of oil, checking for leaks and confirming the proper oil level after service.
After the kids completed their work, I double-checked the drain plug, oil filter and oil level. I also cleaned the surrounding areas (subframe and exhaust) of any splatter.
I completed the usual housekeeping items that the kids did not do (checking the lights, testing the battery, inflating tire pressures to spec, top-off washer fluid, reset OLM, etc.). Plus I also volunteered to do some other maintenance items (brake fluid flush, transmission service). Overall, I think it was a meaningful, productive and successful evening for all parties.
I have done this as well - but in a different way. I removed the drain plug and allowed it to drop into the pan. The plug was just the right size and plugged the center drain hole.Hey now, I just did that myself. In my defense, it was only the 2nd time I used it - I always used the simple, open catch containers. I can tell you that the top basin area in a Flo Tools 16-quart pan holds over 4 quarts !! I got lucky.
