Oil Capacity for a 96 Ford Explorer 4.0 V6 (OHV)
Brickerville, PA
Hey guys, doing the first oil change on my gf's explorer since she got it, but it doesn't have the owners manual with it. Anyone know the oil capacity w/filter? I think its 5qts. for the SOHC 4.0, but hers has the old pushrod 4.0. I gotta replace the Idle Air Control valve, so I figured while i'm under there I'll do a quick oil change.
Buffalo, NY
I'm pretty sure it's about five quarts. Start with four-and-a-half, run it to operating temp when finished, then top off as necessary...
Everett, Washington
Capacities about half way down....... 1996 FORD TRUCKS EXPLORER 4.0L 6-cyl Engine Code [X] FILTERS Oil Filter: EAO15 Absolute Efficiency Oil Filter: Oil Filter: 51515 WIX 51515 Oil Filter Air Filter: EAA416 Absolute Efficiency Air Filter: Air Filter: 46416 WIX 46416 Air Filter Fuel Filter: 33296 WIX 33296 Fuel Filter Trans Filter: 58840 WIX 58840 Auto Tran Filter [1] Trans Filter: 58841 WIX 58841 Auto Tran Filter [2] 1. 2WD 2. 4WD NGK PLUGS & WIRE SETS PLUG GPSERIES TR55GP NGK3403 PLUG IXIRIDIUM TR55IX NGK7164 PLUG PREMIUMPLATINUM PTR5F-11 * PLUG PRERIUMIRIDIUM ITR5F13 ^ PLUG VPOWER TR55 NGK3951 WIRESET WIRESET RC-FDZ036 NGK52184 TRICO WIPER BLADES Blade Class Driver Passenger Rear NEOFORM T16180 T16180 EXACTFIT T181 T181 T122 WINTER T37180 T37180 T37131 LUBRICANTS & FLUIDS Engine Oil Grade 1......API* SAE 0W-30 Synthetic Signature Series Oil SAE 5W-30 Synthetic Motor Oil SAE 5W-30 XL Synthetic Motor Oil All Temps......5W-30 Manual Transmission,.....MA[1] Synthetic Automatic Transmission Fluid Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) Automatic Transmission,4R55E.....MA Synthetic Automatic Transmission Fluid Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) Automatic Transmission,4R70W.....MA Synthetic Automatic Transmission Fluid Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) Differential, Front .....GL-5 All Temps......75W-90 Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube Severe Gear 75W-110 Controlled Slip Differential, Rear .....GL-5*[2] All Temps......80W-90 SAE 80W-90 Synthetic Gear Lube Severe Gear 75W-90 Severe Gear 75W-110 Standard Differential, Rear .....GL-5 All Temps......80W-90 SAE 80W-90 Synthetic Gear Lube Severe Gear 75W-90 SAE 75W-90 Synthetic Gear Lube Severe Gear 75W-110 Transfer Case,Warner 1354.....MA Synthetic Automatic Transmission Fluid Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) Transfer Case,Warrner 4405.....MA Synthetic Automatic Transmission Fluid Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) Fluids Power Steering Fluid.....MA5 Synthetic Automatic Transmission Fluid Brake Fluid.....HBH Series 600 DOT 4 Racing Brake Fluid Clutch Fluid.....HBH Series 600 DOT 4 Racing Brake Fluid 1. Beginning immediately all manual transmission applications requiring MERCON can now be serviced using MERCON-V or MERCON Automatic Transmission Fluid or dual usage fluids labeled MERCON/MERCON-V. After July 1, 2007, MERCON Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory. 2. Limited Slip Identification: Letter & number on plate on door lock pillar. (Models W/ Traction-Lok Rear Axle Add 4 oz offriction modifier part no. C8AZ-19B546A (EST-M2C118-A) CHASSIS LUBRICATION Two-wheel drive 0-6 Fittings, 0 Plugs..........LM Series 2000 Synthetic Racing Grease Synthetic GHD Heavy-Duty EP Grease Synthetic Multi-Purpose Grease NLGI #2 Four-wheel drive 0-10 Fittings, 0 Plugs..........LM Series 2000 Synthetic Racing Grease Synthetic GHD Heavy-Duty EP Grease Synthetic Multi-Purpose Grease NLGI #2 CAPACITIES Engine, with filter..........5.0 quarts[1] Cooling System, Initial Fill..........8.0 quarts AMSOIL Antifreeze and Engine Coolant Automatic Transmission, 4R70W Initial Fill..........5.0 quarts Automatic Transmission, 4R55E Initial Fill..........3.0 quarts Automatic Transmission, 4R55E Initial Fill..........3.0 quarts Automatic Transmission, Total Fill 4 speed 4wd 4R55E..........9.9 quarts 4 speed 4R70W..........14.0 quarts 4 speed 2wd 4R55E..........9.5 quarts Manual Transmission, ..........5.5 pints Differential, Dana 35 Front..........3.6 pints[2] Differential, Rear..........5.5 pints[3] Transfer Case,Warner 1354..........2.5 pints Transfer Case,Warrner 4405..........3.0 pints 1. When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase. 2. Fill no higher than 9.5 mm or 3/8 inch below fill plug. 3. Fill to no more than 1/4 to 9/16 inch below fill plug hole. TORQUES Oil Drain Plug.....15-25 ft-lbs Transfer case Fill Plug.....14-22 ft-lbs Drain Plug.....14-22 ft-lbs Manual Transmission Maz M50D 5-SPD Fill Plug.....29-43 ft-lbs Drain Plug.....29-43 ft-lbs SERVICE INTERVAL AMSOIL Product Recommendation and Drain Interval Guide (g1490) OTHER TOP QUALITY PRODUCTS Mothers® Car Care Appearance Products By-Pass Oil Filters PI Performance Improver Gasoline Additive Copyright ©2008 by MOTOR Information Systems, a division of Hearst Business Media, Inc. All rights reserved.
afoulk
Brickerville, PA
well, went to wally world and picked up a 5qt. jug of good ol' Q.S. dino, a Motorcraft filter, and a bottle of Gumout with Regain fuel system cleaner. Its got almost 95,000miles on it. I was gonna go with Valvoline Maxlife Syn. Blend, but they only had it left in 5w-20. I think I'll go with that next go around, and do the plugs, wires, and fuel filter at the same time.
afoulk
Brickerville, PA
We really lucked out on this one. She totaled her saturn, and this one had just been traded in at the Ford dealer her dad works at. The couple that had it had always had it worked on there and he had just rebuilt the tranny in it last year, so atleast we know the history on it. Its fully loaded other than the fact it has cloth seats and the base engine, it had 93,000miles on it, and she got it for only $3,000.
1/4 Mile Track
After your done changing oil etc, replace the belt tensioner as they are known to fail,ask me how I know
