I have had this question for some time and would like some experts to help me with an answer if possible.
This has happened with more than one vehicle I have owned. Currently have a 2014 Hyundai Santa Fe.
Ok, here goes. I change the oil. I put in the amount recommended in the manual. It checks good on the stick. I then keep my oil checked and add oil when necessary to keep it full. (Both of my last two "newer" vehicles have consumed some oil between changes. This is a whole other topic I don't understand.)
Then, at my next oil change, I drain the oil, and it won't even fill a 5 quart container nearly full. (Guessing maybe 4.5 quarts or so in there.) The capacity of the car is 6 quarts!
I know the dirty filter holds a little oil but I don't believe it holds over a quart in it.
Can someone tell me why this mysterious "phenomenon" occurs?
Thanks in advance for your replies.
